Video Card Purchase
  • Video Card Purchase
    I am ready to pull the trigger on a new video card. Which one would you suggest?
    GeForce GTX 980
    GeForce GTX 970
    They both have 4GB, but the 980 is $200 more on EBay.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    The GTX 970 has 1664 Cuda Cores, the 980 has 2048. I assume you should choose between your workflow. And even if you need Cuda Cores, maybe spend some more and get 2 970 and a new PSU For my workflow, i hardly use RT, and therefor i would go for the 970.
    Hope it helps
    Ralf
      970 for sure. The price to performance ratio just doesn't justify the extra cost for the 980.
      Check out my models on 3dOcean
        For what purpose would this be?
        If it's for RT GPU, go for it,
        If it's for viewport performances, you might want to consider a quadro
        Stan
        3LP Team
          It's for viewport performance.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            970 for viewports
              Okay, 970 it is!
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Okay, 970 it is!
                make sure you dell has enough space in the case to fit it!
                Dmitry Vinnik
                Silhouette Images Inc.
                ShowReel:
                  I will, thanks.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Dell recommends:
                    Support for 2 PCI Express x16 Gen 2 graphics cards up to 150 watts
                    High End 3D:
                    NVIDIA Quadro® 6000
                    NVIDIA Quadro® 5000
                    Mid-range 3D:
                    ATI FirePro V7900
                    ATI FirePro V5900
                    NVIDIA Quadro® 4000
                    NVIDIA Quadro® 2000
                    Entry 3D:
                    ATI FirePro™ V4800
                    NVIDIA Quadro 600
                    Professional 2D:
                    NVIDIA Quadro® NVS 420 quad monitor card
                    NVIDIA Quadro® NVS 295
                    ATI FireMV™ V2260
                    GPU (Graphics Processing Unit for High-Performance Computing)
                    NVIDIA Tesla C2075
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      If the 5000/6000 fit, which I had and is huge, this should fit.
                      http://www.amazon.com/Zotac-GeForce-...cm_wl_huc_item
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        see if the geforce matches the length of the quadro 6000 and also its height as they can be quite fat.
                        Dmitry Vinnik
                        ShowReel:
                          you'll be fine, the quadro is way way bigger.
                            Well, I didn't have the quatro in this box, but it does imply that'll fit in this box (otherwise it would be dumb to recommend it). The box I had it in, it didn't fit, so I had the box hanging open. I wasn't happy at all with that card; it wasn't worth the $2000
                            I'll spec sizes out before I purchase.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              I still recommend the k4200 as I have had really amazing feedback from it.
                              Cheap and only 5-10% viewport difference with the really high end k5000 and k6000.
                              Stan
                              3LP Team
