What's the best way to have both? I'm trying comptex with a+b add, but it doesn't seem to be working.
Texture edge and bump
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
I think using a composite is easier than using a comptex for this purpose
Something like this?
http://www.peterguthrie.net/blog/200...illet-tutorialpaolo vaja
www.3d-arch.it
I'm doing this in my current project. I'm using a VrayCompTex and putting the edgeTex into the "Source A" input. I think I had to have it in source A or it wouldn't work. Even though "adding" the two maps shouldn't matter. But it did.
Timwww.seraph3d.com
Senior Generalist
Industrial Light & Magic
Environment Creation Tutorial
Environment Lighting Tutorial
I also needed different bump values, which isn't possible, so I bailed on the idea. I'll remember your tip next time.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Different bump values are possible via multiple VrayBumpMtls.
Here is an example:
http://ftp.chaosgroup.com/support/mu..._bump_maps.max
Bobby,
not sure it is what you are looking for but in case...
http://forums.chaosgroup.com/showthr...irt-bump/page2
Originally posted by glorybound View PostWhat's the best way to have both? I'm trying comptex with a+b add, but it doesn't seem to be working.
You can still get different bump amounts using the vrayCompTex approach.
The actual bump amount from a texture map is controlled by going into the output rollout for your texture map and adjusting the "bump amount". Think of it as a multiplier for the amount of bump. Regardless of what your shaders bump amount is set to, you can adjust the bump of any map by changing the value in the output rollout.
Tim Jwww.seraph3d.com
Senior Generalist
