Vray Displacement Clipping w/ use object material - Displacement value over 100
  • Vray Displacement Clipping w/ use object material - Displacement value over 100
    I was going crazy trying to figure out what was going on with a displacement test (I don't use it very often).
    Just a simple noise map in a material slot and 3d displacement.
    It turns out that if the displacement value is over 100 in the material, the displacement is clipped.
    Is that as designed? I just assumed the displacement would be more exaggerated.
    If it is intentional perhaps add a note in the manual under the Vraydisplacemod entry since it really threw me off.
    See attached.
Name:	displacement clipped.JPG
    Rising the Texmap Max parameter should help in this case > Click image for larger version
Name:	2014-12-03 18_09_51}.jpg
    Tashko Zashev | chaos.com
      Thanks Tashko. That makes sense. I was primarily writing to see whether it was intentional and to request a note be added to the manual.
        We will see if we can add some more information and examples to the Tex. map min/max section of the V-Ray Displacement documentation part.
        Thanks.
