opacity map with vray matlib
  • opacity map with vray matlib
    hi
    dos any one know if i can creat a tree with a picture of a tree and it's alpha chenel like i do with the max matlib but only the same on the matlib of vray?
    Hi Miki72 !
    Use the refraction slot to put a Black and White image for opacity,
    You may have to "inverse" the image to get White and Black, it works
    in the inverse of a standard material.
    Check the "Affect Shadow" and it should work.
    Bye !
    Gaƫl
      didnt work for me
      my alpha chenel is in the same image of the tree and wen i put it like you say in the refraction it didnt work for me
      mabe im mising somthing?
        try to separate the channels in two files. then it should work.
          i do it all the time with tiff images with alpha.
          a: make sure to set ior to 1.0
          b: add your image to refraction
          c: i usually change mono channel output and RGB channel output to alpha and alpha as grey respectively.
          d: its goot to remove the blur on the bitmaps i find.
          e: and dont forget to invert your image in output
            hey thanks
            i did it with youre help
