panorama exporter problem.
  • panorama exporter problem.
    Heres the thing, i did a test scene on VIZ 4, to see Vray results on the Panorama Exporter feature of VIZ.
    It was a simple room, with 2 levels and an spiral stair, for the stair railings i used a helix line and for the 2d level raillings i used a simple line that, then I set both to renderable and a thickness of 0.01 radius (something like 2 cm thick), when i render the scene, theres no problem, it look ok, however when i run the panorama exporter, the final quicktime movie, doesnt shows pieces of the 2d level railing, like there are missing parts of the line, this doesnt happens on the helix line of the stair railing.
    Any idea on how to fix this?
    are you rendering the scene from a pre calculated irr map?
    Natty
    http://www.rendertime.co.uk
      nope...I cant....I have vrayfree.
      but I solved the problem, apparently the thickness of the "lines" were too small, i just added 1 cm more and it looks ok now.
