Do we know how long it takes to create render elements? Does any one take any longer than another, or are they all the same and take no more time to create. I know extra texture can add 10% to your render times, but what about z-depth, reflection, or any of the other? if I don't use most of the ones I create, does it make sense to just omit them, or does it not matter?
Render Elements
Render Elements
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
any additional buffer adds time. Some more then others, for example zdepth will take a small hit but not as bad as extra tex. I typically only output the ones I need. Also, just adding render elements makes vray use more ram and takes slower then having them disabled so having bare minimum is best.Last edited by Morbid Angel; 29-12-2014, 02:57 PM.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
Okay, good to know.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I have been working on a scene and over the past week my render times, for the final output, was 6 hours. I just removed the 6 render elements I had and it is now less than 2 hrs. I had the basics, plus two extra textures.Bobby Parker
phone: 2188206812
- Windows 11 Pro
if you have consider for antialiasing on in the extra tex, this will slowdown your rendering but really it shouldn't be 6-2 hours as this sounds a bit too extreme.Dmitry Vinnik
ShowReel:
Originally posted by Morbid Angel View Postif you have consider for antialiasing on in the extra tex, this will slowdown your rendering but really it shouldn't be 6-2 hours as this sounds a bit too extreme.Bobby Parker
phone: 2188206812
- Windows 11 Pro
2 hours with a lot of displacement, both 2D and 3D, Forest Pro grass, all at 5100 X 2870.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by Neilg View Postlight selects take forever, they essentially render the image twice. I only use them on low res tests initially if I want to play with the lighting balance, then once i've got it figured out i go back into max and match what i've done for the final render.Bobby Parker
phone: 2188206812
- Windows 11 Pro
well a few ambient occlusion passes will most certainly also add to render time. Typically you don't need ao in architecture (some people use it) but its really not necessary. The need of AO means lack of texture/surface detail so people use it to push those effects more.Dmitry Vinnik
ShowReel:
I find that I can render with lower settings and get the fine detail with the AO. However, I can render an AO fast with a light material and GI off.Bobby Parker
phone: 2188206812
- Windows 11 Pro
