What is the new VRayFakeFresnel map all about?
VRayFakeFresnel?
It's somewhat like the Falloff map in Fresnel mode, but uses Schlick's approximation to the Fresnel term. Instead of working with an IOR, it just needs a front reflectance and grazing angle reflectance. It matches the BRDF curve used by the Arch&Design material.
VladoI only act like I know everything, Rogers.
Originally posted by tzaar View Postand the reason for using it over a falloff map would be speed or something workflow related?Software:
Windows 7 Ultimate x64 SP1
3ds Max 2016 SP4
V-Ray Adv 3.60.04
Hardware:
Intel Core i7-4930K @ 3.40 GHz
NVIDIA GeForce GTX 780 (4096MB RAM)
64GB RAM
DxDiag
yeah I suspected it being, as you wrote, to easily set the face and border reflection amount. A falloff map isn't that hard either to set up, but let me understand the curve better. This curve value is not that obvious to me. But maybe it makes sense to some people and is good if you want to do things in a correct manner and enter data from some sort of measurement or chart?
Still curious if it's faster than fallof, but too lazy/busy to set up a test.
Sorry for bringing up this old thread but is there info about this map anywhere? It's been bugging me to find out what's this map all about. I don't see anything said about it and there's neither description for it in the help page nor anywhere else on the internet.
I played with this map and it looks like Max's Fallof map as others have mentioned. I would like to know when and why we should use it and what's the difference to Falloff except for the way the user inputs the values that describe the fresnel effect. Maybe we should have this map explained in the help page so it's clear how it is used and what we can accomplish with it.
Vlado, could you tell us why this Schick sampling is important? Does it give us any advantages to Falloff?Last edited by Alex_M; 20-09-2015, 08:00 PM.Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14
... or what about using this Complex Fresnel shader, if metals have to look really good?
http://docs.chaosgroup.com/display/O...Fresnel+shader
... has anybody tried this approach?
Best regards, Nils
Originally posted by WilleViz View Post... or what about using this Complex Fresnel shader, if metals have to look really good?
Best regards, Nils
