Load your current active viewport into the Vray VFB so if you want to do quick region tests you don't have to guess or do a quick render to see where you need to draw your region.
It's a macroscript so just run it and go into customise user interface, under DW Tools assign it to a hot-key or menu/quad button.
This will turn safe-frames on automatically so it can capture the full viewport area, let me know if you think it should turn safe-frames off again afterwards if they weren't enabled before-hand....
Updated: It now maximises your viewport to give you the highest resolution possible and it also resizes the image to your render size so your frame buffer won't resize. (Thanks Vlado!)
Updated: Fixed crash with VRay RT as production renderer
It doesn't work with the Vray RT VFB, bug Vlado about it if you need it
If you like this, check out my other Vray Script here:
Vray Render Mask Maker
http://forums.chaosgroup.com/showthr...der-Mask-Maker
