spawners not loading vraydummyscene
  • spawners not loading vraydummyscene
    hi,
    updated the farm to sp3 and vray31002 yesterday, now two machines don´t load the vraydummy2015scene (and of course refuse to connect/render), all other machines work fine. Was ok before the update. Any idea somebody?
    Matthias
    Have a look at this thread:
    http://forums.chaosgroup.com/showthr...rcasm%29/page4
    I installed the nightly and it is now working fine.
      hmmm, installed the nightly vray 31002 build 25427 dated 20150106 - spawners still don´t load the vraydummyscene and connect with 3dsmax sp3. any idea?
        sorry, the nightly works with sp3 - it just doesn´t show the "vraydummyscene" in the taskbar.
          Did you start V-Ray Spawner manually or as a Windows Service ?
            Im not using service, i run the spawner.exe from an autostart entry instead. All machines Running Fine now with sp3 and the actual Built. Didn't try backburner
            Matthias
              The slaves should render fine even if the V-Ray slave has been started and doesn't show "V-Ray Dummy" in the taskbar with the latest stable 3.x nightly builds.
              However, we are now working to find solution for this issue as well.
              Tashko Zashev | chaos.com
