Find out VRay version used in file
  • Find out VRay version used in file
    Is it possible to find out which Version of Vray was used to last save the file ? I have an assignment where the client is handing off files which were being worked up on by someone else & he explicitly wants me to use the same Version of VRay as the previous person did. Im on 3.1, so is there a way I can look for the version / build within the files they have sent me ? (Apologies in advance if this is a n00b question)
    Thanks,
    Best Regards,
    Ashish
    CG Generalist & Matte painter
    www.ashishdani.com
    If you run a file through the 3dsmaxcmd.exe command, it will print the version of the renderer that was used.
      Thanks Vlado
      Best Regards,
      Ashish
      www.ashishdani.com
