Vray Embree Test
  • Vray Embree Test
    Hi I am a 3ds max design 2014 and vray 2.40.04 user, after i get some comment from this forum, i know that vray embree can speed up render time for around 25% to 30%, i am very happy and finally give a try today, but the result is disappointed me.
    Attached some jpeg image here for your review:
    Jackie Teh
    3ds max design 2023, V-Ray 6, Update 2.1 [6.20.07 build 32575]
    AMD Threadripper 1950X @3.40 GHz | 64GB RAM | Nvidia RTX 3070 ti
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    It's an Intel thing. Do you have an Intel processor? Also, it's a 3.0 thing, I think.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
      However, you images look exactly the same, to me.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Hi Glorybound,
        Yes i have a intel core i7 3820 processor which is support SSE and AVX in the CPU.
        According to what i learn from this forum, Vray 2.40.04 user cannot get embree plugin from the following link:
        http://help.chaosgroup.com/vray/misc/, after extract the file, copy the vrayembree2013 in the 3ds max plugin folder, because it dont have vrayembree2014 in the folder, but it has been confirm from this forum that you can use vrayembree20133 instead. am i missing anything??
        The image look same, but my question is with embree it only increase 1 minute fatser rendering?? not 25% to 30%??
        Jackie Teh
          That's right, I forgot. I haven't heard much about Embree, so I don't think that it turned the industry on its side. I do know that it works better than VRay's core algorithm. People smarter than me will know more and might response with more help.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Thank you and i really hope someone will me to find out how to decrease more render time with embree.
            Jackie Teh
              In V-Ray 2.x, Embree will only accelerate static geometry so it's best to set the default geometry type to "static" in the V-Ray System tab. Since V-Ray 3.1, Embree can accelerate other kinds of geometry too.
                Hello,
                I guess Embree will show more rendertime speed up for more complicated scenes ... here we can see big improvements with our (big) scenes, when it comes to deal with several millions of polys, thousands of objects ! I may be wrong, but TBH, I wouldn't expect big improvements with a single object shot
                Nicolas Caplat
                www.intangibles.fr
                  I did set the default geometry type to "static"
                  Jackie Teh
                    Originally posted by NicoC View Post
                    Hello,
                    quite agree with you, i will try embree again when i work on big scene
                    Jackie Teh
                      Hi just give some try render with a simple scene with embree, i am using Vray 2.40.04
                      I have one VrayDomeLight(Subdiv: 32) with HDRI in this scene with the below setting:
                      Render size: 800px x 600px
                      Overide mtl: On with Vray Mtl white
                      AA: 1/6
                      color mapping: sub-pixel mapping On, Clamp output lecel: 10
                      Irradiance map: Preset low
                      Light cache: subdiv: 500
                      Noise threshold: 0.01
                      Default geometry: static
                      Here is result:
                      No Embree
                      Embree Default
Name:	embree on default.jpg
                      Embree bhv2
Name:	embree on bvh2.jpg
                      Embree bhv2.spatial
Name:	embree on bvh2.spatial.jpg
                      Embree bhv4
Name:	embree on bvh4.jpg
                      As you can see all the image have anti-aliasing issue and a lot of white spot, and also the render time is a little difference with no embree one.
                      Jackie Teh
                        Continue from previous
                        Embree bhv4.spatial
Name:	embree on bvh4.spatial.jpg
                        Jackie Teh
                          I assume the white spots are because of not enough samples, can you post some Sample rate passes and you can also try with version 2.50.01
                          You can also post the scene too and we will tell you what are the times with version 3.0.
                          Tsvetan Geshev
                          Chaos Group
                            Originally posted by tsvetan.geshev View Post
                            I assume the white spots are because of not enough samples, can post some Sample rate passes and you can also try with version 2.50.01
                            how to increase samples? is it increase dome light subdiv?
                            Jackie Teh
                            • #15
                              Increasing the Dome-Light subdivisions should help to reduce the white spots noise.
                              Decreasing Color Threshold value from Image Sampler should help to improve Image Sampler quality.
                              If the above tips do not help please send us the scene for investigation.
