Node dropping bitmaps
  • Node dropping bitmaps
    I keep having problems with one of the nodes on my DR network. I randomly drops some bitmaps when rendering. I always use UNC for all paths. The node renders fine when I load the project and render on the without DR. When I switch DR it drops the maps. The node has always worked before. Has anyone ran into this before?
    how many nodes do you have and which OS is storing the maps?
    sounds like a max connections error.
    Reflect, repent and reboot.
    Order shall return.
      I have 5 nodes al XP Pro connected to a sever wtih NT 4. It's always worked before. Any way I fixed it! I deleted the 3dviz.ini file to force it to build a new one and now it works. It might be interesting to compare the old and new to see what it was.
