off topic: archviz birdview stills camera matching howto?
  • off topic: archviz birdview stills camera matching howto?
    After several (unsuccessfull) tries wit the old 3dsmax camera matching point helpers and also with the new 3dsmax perspective matching utility I would like to ask all the successfull archiz-artists how they match their shots.
    We often get wide angle still shots from drones like Phantom Vision carrying lots of exif datas like apertue, focal length, gps-data, we have the corresponding arch drawings and reference measures from existing buildings in the shots but don´t get the exact matching, left with the feeling of roughly stumbling around with the camera.
    Do you use specialized software or what´s the trick?
    Looking forward to get illuminated, Matthias
    In the meantime looked at PFMatchit and Syntheyes, more or less same price. Somebody has experiences with matching birdseye stills?
      usually do it by eye.. with a bit of practice its much quicker than trying any fancy automated methods.. when doing animation with heli footage thats a different matter.. i use boujou in this case.
      im not sure what camera you are using on your drone, but are you correcting for lens distortion before trying to align?
        I almost always do it by eye too. Knowing the lens width removes one big parameter from the equation.
        If I have several aerial shots to do I run them through Syntheyes so I get all the cameras in one go.
        mekene
          I find gps works pretty well as a starting point for heli shots. then go by eye. though I've only done real heli + dslr matching. which are taken a lot further away than a drone. you also need a gis workflow to get gps points into max.
          ground level gps is useless. so if you drone shots are close i wouldn't bother with it. I also imagine you have some pretty weird distortion going on too with the drone cameras.
            lens correction as the "first big step" really helps if there are lcp-files provided by adobe or camera manufacturer. often the drones have weirdcheapultrawideanglefisheyelenses - is it really try and error then? It takes more time matching the view than creating the 3d-scene (thanks to vray). I´ll go for the syntheyes 15-days-trial, maybe that helps a bit.
            Matthias
