Vray materials problem
  • Vray materials problem
    I'm try to create a simple metal cladding material for the exterior of a building I have modelled, but I just can't get what I want. Can anyone advise me on how to do this? It needs to be a light grey (which no problem to do) with a subtle sheen, which is where I'm having problems.
    Merch
    hi
    well you could do it several way's.
    you could have a vray material, reflection = grey with glossy at around 0.6 with 10 sibdivs... or there abouts you'll have to play with the settings to suit you.
    or you could use a standard material give it the specular level that you want and then place an Omni in your scene with just specular ticked, that will give you quite a nice sheen to the metal.
    hope this helps
    regards
    Natty
    http://www.rendertime.co.uk
      For metal w/ VRayMat you should also use the Ward shader and set Fresnel on with an IOR from 8-16 or so.
      --Jon
