"no sequence environment is present?"
  • "no sequence environment is present?"
    I'm checking out the .vrmat files downloaded from the website & wondering what the warning about the sequence environment means for the VrayVRMatMTL? Anything I can change to fix it? (Honestly only annoying because right now I'm rendering scenes of all the vrmats at once so I get 60+ warnings lsited in the message window.)
    | LinkedIn | Twitter | JCanimator.com |
    I've just run a quick test with a few random VrayVRMatMtls downloaded from our website but I didn't get any warnings during the rendering.
    Would it be possible to give us some of the names of the materials you are using so we could test them here?
    Let us know also the exact version/service pack of V-Ray that you are using.
      Max Design 2015 Ext2 w/ Vray 3.10.01.
      59 of 177 Bath Tiles materials get this. Pretty sure I was getting it on lots of the glass ones too, and those are just the first libraries I started with.
      Specifically - Vray_Bath_tiles_160_perl is one that the warning occurs on.
        Thank you very much for the clarification.
        I got the same warning with the shared material - I'll have to discuss it with our developers.
        I'll let you know when I have some news about it.
        Do you get any issues with the final render?
          This warning is actually relevant to V-Ray for Sketchup/Rhino not to V-Ray for 3DSMax.
          There is nothing to worry about - everything should work fine.
          The warning will be removed from V-Ray for 3DSmax.
            Awesome, yeah everything looked okay I was just confused since I had never seen that warning text before, so it being SketchUp / Rhino related makes even more sense. Cool, thanks!
