Need normal map creation workflow
  • Need normal map creation workflow
    I've been searching the web for a good workflow for creating normal maps in VRay. Part of my problem may be ignorance. I'll explain what I'm doing.
    Let's imagine my model is a shader ball. It's pretty smooth with curves and surfaces, just a nice model. I now need a normal map and AO map for it to use in other programs. I'm not worried about polycount as I'm not doing a game. Do I have to use the Lo Poly/Hi Poly baking workflow to get the normal map? Can I just use my Hi Poly mesh and generate a good tangent space normal map? That's what I'm trying to do but I can't figure it out.
    Does anyone have a good workflow for me?
    V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
    Autodesk Expert Elite Member
    How do you intent to use those maps afterwards?
    If polycount not bothers you why don't you use the original high-res meshes in other program?
    A normal map usually represents a difference between high and low resolution geometry and both meshes are required in order to generate it.
    VrayNormalsMap could be generated from Render to Texture window - just select low resolution mesh activate projection, pick the high-res mesh and hit Render button.
    Ambient Occlusion map could be generated from a single mesh again using Render to Texture feature. A specific thing here is that you have to export VrayCompleteMap and the objects from which the map will be generated should have V-Ray Light Material applied with VrayDirt texture in the Light Color slot.
    Let us know if you need further assistance on that matter.
