Convert old materials to GGX shader?
  • Convert old materials to GGX shader?
    Hi everyone,
    I really like the latest shader model, GGX that is popping op in all the different renders, including Vray.
    But I was wondering if anyone has made a script that allows me to basically convert entire old scenes to use this? (I understand that technically certain values behave slightly different)
    And also is there a way to force vray to set ALL newly created materials to GGX ? instead of having to switch it every single time?
    Thanks
    Just posting because I like the idea about GGX being default.
    A.
    www.digitaltwins.be
      Assuming your selected objects all have a VRayMtl applied (or it won't work) type the following in the script listener window and press enter on the numeric keypad:
      $.material.brdf_type = 4
      Also you could try the VMC script off Script Spot. You will then need to find the brdf_type in the dropdown and change the value to 4.
        Better yet:
        Code:
        for obj in selection do
        	if obj.material != undefined and ClassOf obj.material == VrayMtl then
        		obj.material.brdf_type = 4 --ggx brdf
        Save that to a .ms file. Make a selection and run it. You should be OK if you end up selecting lights, etc.
          Code:
          for o in getclassinstances VrayMtl do o.brdf_type = 4
          I generally find I have to increase the glossiness value when converting. Here's with a 10% increase.
          Code:
          o.brdf_type = 4
          o.reflection_glossiness *= 1.1
          Maxscript made easy....
          davewortley.wordpress.com
          Follow me here:
          facebook.com/MaxMadeEasy
          If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
            Would this brdf work for all material types?
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090 X2
            • ​Windows 11 Pro
              Awesome guys!!
              Thank you for the effort and the scripts!
                All I need now, is for it to work with multi sub materials :$ it doesn't seem to like those.
                  Did you try Dave's script rather than mine? I haven't tried it, but it looks like it would work with multi-sub. Mine would not.
                    Yeah I am also wondering if GGX should be used for all materials????
                    Ashton Woolley
                    Senior CGI Generalist
                    ASHTONWOOLLEY.COM
