Hi all,
After many years of hit and miss experiences rendering though Backburner, I have finally got round to testing Deadline 7 on a 30 day trial. It's certainly a lot more powerful (and complicated) than BB, but essentially the main thing I'd like to use it for is to send DR jobs to just one of my two render nodes, with the 2nd node running the VRay DR spawner, so that both nodes render the same image. I can then use my workstation for other production tasks.
With Backburner, the set-up described above works fine (most of the time), but with Deadline the only way it works is if you use "Workstation mode" when submitting the job, which needs a full/workstation license of 3ds max on the node/slave you're sending the DR job to. Unfortunately, I only have the one license of max and that's on my Workstation, which defeats the object of sending a DR job to a slave so that I can work on something else. If you don't tick "Workstation mode", the slave renders alone, without DR kicking in. I've tried it with Deadline Slave running on the 2nd DR node and with VRay Spawner running without Deadline Slave.
Anyone found a way to do this?
I have seen this post below and the related post on the Thinkbox forum, but it doesn't help, as davexl ended up using the workstation mode:
http://forums.chaosgroup.com/showthr...light=deadline
http://forums.thinkboxsoftware.com/v...p=58148#p58148
I'll post on the Thinkbox forum as well, but I thought someone here with a similar small set-up might have run across the same problem. I'm running max 2015 and VRay 2.50.01
Thanks.
Thanks.
