blend material - tiling issue with opacity map
  • blend material - tiling issue with opacity map
    I am trying to add a label/ sticker to an object...
    Using the vray blend material, I have my base material, the 'sticker/ label' material, and masking that is a bitmap of white text on black.
    I am getting some funkiness with the map. I have tiling turned off but it is not doing what I want, please see the attached images and you will see what I mean.
    The sticker/ label of the words 'wireless' should just be white against the light brown paint material without those nasty edges.
    It is as if I need an opacity mask for the opacity mask! How do I stop it from continuing past the bitmap as I have already turned off tiling?
    Anyone? Need this for a job I'm working on right now, any help is greatly appreciated!
      It almost looks like there is another, larger white text mixed in somewhere. Sorry, but I don't know a lot about this material.
      Hopefully someone has a quick answer!
      Best regards
        Solved! Made the blend amount black.
