I am trying to create 2 different Depth elements, but it's not working. One works, but the other one comes out not as expected.
ZDepth
ZDepth
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
It's kind of a messy one, I had similar issues a few years back with elements that were called the same thing - it's like the same information was written into two channels. A thought though is to just use an extratex pass and put in a falloff map in distance blend mode, with the near and far set to the values you'd use for your zdepth, it'll be pretty similar.
I regularly use more than 1 z-depth pass without problems. Only problem I have is sometimes forgetting to rename the addition passes which get overwritten when you batch save the passes.
This one worked... I am not sure what was happening.Bobby Parker
phone: 2188206812
- Windows 11 Pro
