Intances And vray..
  • Intances And vray..
    Anyone have had problems using massive poly instances?, when i select instanciate in system tab and render the machine need very much ram that with replicate... and also several dark splotches appears.. any suggestion?
    i dont think its the instance...dark splotches due to material error...
    Reza Bahari
    visual3d@streamyx.com
    013-3428162
      this is normally due to deffective geometry. flipped normals, double sided, or mirrored instances. I thought it was somehow fixed. Check your materials, (force double sided, etc).
      Good Luck.
      Alejandro Gonzalez
      alejandro.gonzalez@zerofractal.com
      Zerofractal - Visual Communications
      New Website! www.zerofractal.com
        all my mats are vray ones, but happens with mirrored instances? i have used some of them, may it be the problem?
          yup it can be. try using the mirror.....opps wait, i just caught myself. its an instance. if you use mirror modifyer it applys it to the other instances as well opps
