Want To Create Random Mat and Tex Variation on VrayProxy
  • Want To Create Random Mat and Tex Variation on VrayProxy
    Hi everyone,
    As in the title, I Want To Assign Different Mat on VrayProxy objects.
    (create random material and texture variation through object and material ID- or any other way that I am not aware of)
    Can't assign object ID or mat ID on Vray Proxy.
    Anyone know a possible solution ?
    Thank you.
    for my blog and tutorials:
    www.alfasmyrna.com
    Originally posted by pixela View Post
    Hi everyone,
    Thank you.
    I doubt you didn't think of this, so it's possible this isn't what you're looking for, but what about Forest Color with Forestpack? http://docs.itoosoft.com/display/FOR...K/Forest+Color
    A.
    www.digitaltwins.be
      If I understand you correctly, you can do it with VrayInstancer and VrayMultiSubTex map.
      See Vlado's last comment in this thread:
      http://forums.chaosgroup.com/showthr...-VRayInstancer
        Thanks for the replies. My proxy object is not a tree or a forest but it is an architectural element which will be placed on specific coordinates (not random) but will be repeated many times.
        So particle flow, vray instancer/particle flow, multiscatter, forrest pack is not an option for me.
        I solved the problem. I was using a script to assign object ID on my proxy objects and this scripts probably didn't work properly yesterday. Today when I use a different script, I was able to assign random Object ID to my instanced proxy.
        www.alfasmyrna.com
          You could also make use of the render id which is naturally random.
            Where is the RenderID parameter for a geometry located?
            Is it hidden to the user and does only Vray read it?
            www.alfasmyrna.com
              I don't believe it is changeable by the user. It's generated at render time and is unique per node (up to some limit).
                MultiSubTex by Render ID.
                Software:
                Windows 7 Ultimate x64 SP1
                3ds Max 2016 SP4
                V-Ray Adv 3.60.04
                Hardware:
                Intel Core i7-4930K @ 3.40 GHz
                NVIDIA GeForce GTX 780 (4096MB RAM)
                64GB RAM
                DxDiag
