Is there a way to exclude objects from something that's using LightMtl as a light source, much like you can exclude objects from a Vray light?
Exclude objects from LightMtl?
David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2024.2.1 Update
V-Ray GPU 6 Update 2.1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
But is it possible to make a circular mesh VRayLight in 2.4?David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
Sure. Just create a circle spline convert it to editable poly and make it a mesh light.
Originally posted by ralphr View PostSure. Just create a circle spline convert it to editable poly and make it a mesh light.David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
Originally posted by Streetwise View PostYou lost me at "make it a mesh light". I think that can be done in VRay object properties, but you still can't exclude anything.
Scroll down in your modifier panel with the light selected and find the pick mesh button
Select the previously created mesh (in your case the circular object)
