I don't know if this was asked before but, Ist there a way to load Vray for Max entirely from a Network location without installing it on the local machine?
Loading Vray completely from Network
Yes it works - please check the following page how to set it up:
http://docs.chaosgroup.com/display/V...om+a+.zip+File
Originally posted by möbius View PostI don't know if this was asked before but, Ist there a way to load Vray for Max entirely from a Network location without installing it on the local machine?
http://docs.chaosgroup.com/display/V...trary+location
Let us know if you have any questions or difficulties to set it up.
Sweet, So in my case where I have to have our IT dept install updates on over half my render farm which is a pain I can create a central folder for the slaves and just update the one folder when needed to update all the slaves?Cheers,
-dave
■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
Hey Guys, thanks for the response. Well we were looking for a way to run the whole Vray package on the workstations but i presume the reason for the current limitation is Max since it seems to work in Maya. But you said you're working on it so i guess we can wait and for the time being we will stick to our current deployment method.
Thanks!
Originally posted by svetlozar.draganov View PostAnd here it is how it could be loaded from arbitrary location in 3DSMax:
Originally posted by AlexP View PostHow do you run the spawner using this? Is it as simple as just replacing 3dsmax.exe with Vrayspawner2015.exe?
We'll have to think of some better way to do it for; the spawner supports an .ini file that tells it where the 3dsmax.exe is located but the location of that .ini file is hard-coded right now - it needs to be a command-line argument.
VladoI only act like I know everything, Rogers.
Originally posted by Paul Oblomov View PostOr use deadline!
That's something that I am looking for since a long time.
Do you mind sharing it?
Thanks
Originally posted by m_hinks View PostHa, I've been trying this with the help of Thinkbox, and not completely got it to work. They have issues with admin permissions! Mind sharing here or PM? I've got a bat file that can install vray, Railclone, forest, and 3dsmax in one hit using command line, but not through Deadline.
I've tried setting up Max 2016 using the "arbitrary location" instructions and I think it's working. (And I really like doing it this way).
However all these machines previously had Vray installed for Max 2015. If I was starting with a fresh machine with no Vray history -- how would the machine know what to use for the license server settings?
