render size
    Originally posted by Neilg View Post
    what on earth is happening. Absolutley do not render at 30k.
    Read this - http://www.scss.com.au/family/andrew/camera/resolution/
    With an 8ft image your viewing distance is a couple of feet away - you should render at 90ppi MAX, which is a 3dsmax/photoshop resolution of 8.5k. I'd assume a 3-4ft viewing distance and render at 6k for that job.
    printers do not print 1 dot of ink for every pixel, it's not possible for it to hold that much detail. you should always be half or less than the printers dpi before even getting into viewing distance.
    Thanks for the article, i will read it carefully, bytheway, may i know is 90ppi MAX?
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
      Originally posted by theedge View Post
      Yes, with 90ppi you are more than safe. Most print shops to whom I submit images for large prints only ask for 30-50 dpi actually !
      ppi? dpi??? what is the differemce between them?
      Jackie Teh
        yeah, 90 is on the high to overkill end. we usually use 60 on 8-12ft prints.
        Thanks, i will keep 60ppi - 90ppi in mind when i discuss with client in future
        Jackie Teh
          dpi/ppi, most of the advice in this thread was really bad and i wanted to emphasize that.
          oh no, so which one should i follow if most advice is bad?
          Jackie Teh
            Perfect Resize 9 has a billboard mode
            thank you, will have a look on it
            Jackie Teh
            • #21
              I'd agree with Neilg, i wouldn't even consider rendering something of that scale at 300dpi! In years past billboard dpi was 45dpi standard (UK).
              As for the differenece between ppi and dpi, probably worth reading this rather than me trying to explain it myself... http://99designs.com/designer-blog/2...he-difference/
              So, the way i tend to approach stuff like this is to get the billboard or building wrap size and then find out from the printers what they intend to print at (A good printers will know what dpi should be used at various viewing distances and in some cases will have run off a few print tests at various dpi's to show the client).
              For arguments sake, we'll say the area is 12ft by 8ft and the viewing distance is 60dpi. I'll then go into Photoshop and setup a new image and use the dialog box to input your sizes and your dpi (ppi) and hit enter, see image;
Name:	new image size.JPG
              If you then open the image size on the new file and switch your width and height to display as pixels you should get this;
Name:	image size 60.JPG
              If your client/printer decides they then want it at 90dpi, change the res to 90 and you should get a new pixel size as below;
Name:	image size 90.JPG
              9 times out of 10 we render at 6000px on the longest edge unless otherwise requested to by the client. As Neilg said with viewing distance properly taken into account it's rare that anything higher is required.
              http://www.the-neighbourhood.com
              • #22
                [ATTACH=CONFIG]24944[/ATTACH]
                [ATTACH=CONFIG]24945[/ATTACH]
                [ATTACH=CONFIG]24946[/ATTACH]
                Thank for the article link and your brilliant idea.
                Jackie Teh
                • #23
                  No problem, glad it's of use
                  • #24
                    Here, is a good little article:
                    http://www.creativebloq.com/graphic-...ution-71515673
                    Bobby Parker
                    www.bobby-parker.com
                    e-mail: info@bobby-parker.com
                    phone: 2188206812
                    My current hardware setup:
                    • Ryzen 9 5900x CPU
                    • 128gb Vengeance RGB Pro RAM
                    • NVIDIA GeForce RTX 4090 X2
                    • ​Windows 11 Pro
                    • #25
                      Thank you, will click it and read the article.
                      Jackie Teh
