How to speed up process rendering
  • How to speed up process rendering
    How to speed up process rendering in vray what installations it is necessary to apply??
    hi and welcome.
    Actually it depends on what youre doing..animation or still images. if its going to be an animation..using vray or any other 3rd party renderer is slower than standard light with scanline rendering....you have to ask yourself what is the output youre trying to achieve. Vray will definitely give you a better rendering but at a time cost. the number of lights with shadow or types of shadow...raytrace is the slowest so stay away from them...you can try using advance raytrace or vray shadow...but if speed is what youre looking for then you have the dependable shadow map.
    next the amout of reflections of blured reflection makes a computer go crazy...refraction is a nother thing to consider....where things are not too visible using opacity map is much faster than ior with vray..
    the faster the processor the better....but if you have a large model...2gb ram would help. not to forget...dateline.
    Reza Bahari
    visual3d@streamyx.com
    013-3428162
