passes switch in V-ray?
  • passes switch in V-ray?
    I was trying to quickly turn off transparency to make test renders, but could not find any way, without changing the materials which uses transparency.
    Is there a flag i can turn off for transparency in V-Ray? Or Max 6 for what it matters?
    Thank you
    regards,
    Gio
    You'll find it in the VRay :: Global Switches rollout.
    Turn off reflection/refraction.
    Torgeir Holm | www.netronfilm.com
      Thank you, that was not it, but it made me look in the right spot.
      I needed to set transp levels to 0.
      Interestingly, the objects were opaque, but the shadows were still as if they were transparent.
      Probably I also need to un-check "transparent shadow" under the light settings...
      Thank you again,
      Regards
      Gio
