VFB ICC switch - Backburner?
  • VFB ICC switch - Backburner?
    Hi Team
    So the ICC works great for stills, but what about animation via backburner?
    Asset tracker doesnt list the ICC file, so then if I split the channels, how would the render nodes save the file with corrections without the ICC file?
    Would I have to manually copy over the ICC to each node?
    Kind Regards,
    Morne
    ICC profiles are only for VFB preview, they are not taken into account when the image is stored on the hard drive.
    So both local and BB rendering should write the same image.
      But when the channels are split, the beauty contains the VFB adjustments.
      So then again, how would the slaves know via BB to apply THAT specific icc?
      Kind Regards,
      Morne
        my backburner is getting my monitor icc. at least it shows it in vfb. but renders are saved with 2.2, not that specific correction.
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
          The VFB will use the ICC profile only for preview purpose. What do you mean by spit channels?
