Any other tips to make ForestPack render faster - in animation?
  • #16
    Originally posted by digitarch View Post
    we´re also creating a landscape camera animation with forestpro forests - when using the new stochastic opacity mode (much faster with our scene now!) for the opacity mapped leaves, do I keep the default bitmap filtering enabled or shoud I disable now with stocastic? Also, what about the bitmap blur, keep to 1 to minimize hard edges?
    Matthias
    The opacity texture is filtered as normal when using the stochastic mode and the bitmap blur parameter should also affect the map.
    You can experiment with several frames (in region render) and see how it goes with the current setup. Then you can try to add more blurriness to the map, if there is any issue.
    Tashko Zashev | chaos.com
