Distributed Rendering & Network Limitations ?
  • Distributed Rendering & Network Limitations ?
    Problem:
    3dsmax file size is reaching 1 GB. Distributed Rendering is failing.
    Error I am receiving from the Log:
    Host is busy
    Vray doesn't initiate the render anymore / game over.
    I delete geometry and bring down the 3dsmax file size to 500MB - it works again.
    Question:
    Is this a Vray Limitation ?
    Or is it a network problem ?
    We upgraded to a 15GB strong network which should actually handle this.
    Number of total Renderblades in the network: 21
    What you think ?
    How to fix that issue ?
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    I don't think I ever heard of a 15 gb network. The best network is 10gb, but when you upgrade you need to have a special network card in your box/render server that can read that fast and a network switch that's capable of reading 10gb speed. Is that what you have?
    regardless, what's probably happening is that it takes a while to open your 1gb file. By that time you cancel the render and network machines stall trying to load/unload that file. I remember dealing with large files over DR and it works fine but they kick in late during render.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      We had an issue when transferring very large files, I think the limit was 2GB though. Maybe it's possible to use X-Refs for some of that, to avoid large transfers?
        Have you tried enabling "Compress on Save" in the File Handling option in 3ds Max. I used to deal with 1GB files with 3d4Medical files I was working on. These had all the working Systems of the body.
        Enabling this easily brings that down to roughly 1 quarter the size if I remember correctly. I think this also makes the normal save faster. I have a similar problem with industrial CAD files I get to convert to poly. Same applies.
        Not sure if it will help you or not.
          Yes always use compress on save, the project I'm woking on currently goes from 500Mb to 53Mb with compress on save, really worth it
          Stan
          3LP Team
