Math for Comping Elements
  • Math for Comping Elements
    Hi all
    I know this is all over the forum, but it's always a mission to find the right info, so
    Please can we have a section in the help docs here:
    http://docs.chaosgroup.com/display/V...r+3ds+Max+Help
    ...for math of comping elements to rebuild the beauty pass.
    1) when to add, when to multiply
    2) How to make your own RAW passes without rendering the RAW passes. Something gets devided by something etc.
    3) When to use filtering and when NOT to use filtering in the element.
    Alternatively, if not in the docs, can we have a sticky in the forum for this please!
    Kind Regards,
    Morne
    It's not too complicated.
    Reflection, Specular, Refraction All go on 'Add' (Normal, linear add) in any order
    RawtotalLIghting * Diffuse = TotalLighting
    RawGI + RawLighting = RawTotalLighting
    Diffuse / Reflection Filter = flatDiffuse (not normally needed)
    RawReflection * reflectionFilter = Reflection
    RawRefraction * refractionFilter =Refraction
    Maxscript made easy....
    davewortley.wordpress.com
    Follow me here:
    facebook.com/MaxMadeEasy
    If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
      Thanks Dave
      If we can sticky this or put it in the docs so it's easy to find again it would be great!
      So ignoring the RAW passes for the moment. To get the beauty I add everything?
      So diffuse + gi + lighting +reflection + refraction + specular = beauty?
      Kind Regards,
      Morne
        Not quite right....take diffuse out of your list and then you'll get the beauty. Assuming you don't also need SSS or self illum passes. The GI and Lighting passes already have diffuse information in them so diffuse is not needed to recreate the beauty in the case your asking about.
        Also, Multiplying passes like rawLighting * Diffuse is almost guaranteed to give you edge issues in your comp. Anytime your multiplying passes your likely to have edge issues. This is where dividing passes to create other passes is the solution.
        One other important bit of info is that you can only comp elements together and recreate the beauty if your using floating point renders. You probably already knew that, but in case someone else reads this thread and is just starting to learn about this its a very important detail to know.
        Tim J
        www.seraph3d.com
        Senior Generalist
        Industrial Light & Magic
        Environment Creation Tutorial
        Environment Lighting Tutorial
          Tim J
          What if I also need SSS and Self Illumination passes?
          Kind Regards,
          Morne
            Some more math for you. : )
            http://forums.chaosgroup.com/showthr...845#post660845
            Rens Heeren
            Generalist
            WEBSITE - IMDB - LINKEDIN - OSL SHADERS
              Originally posted by Rens View Post
              Thanks Rens, great write-up
              Kind Regards,
              Morne
                Rens covered it in that other link, but both "should" be a simple plus as well. I have not needed to render a separate SSS pass for a while now, but I know roughly two years ago it was not adding back up correctly. At the time I was having to subtract out everything else leaving behind my own SSS element.
                Tim J
                www.seraph3d.com
                Senior Generalist
