I am a bit curious about why V-Ray Lanczos was chosen as a default filter. First thing that interests me is that V-Ray docs say:
From what I understand, Lanczos falls into sharpening filter category as well, as the curve profile goes into negative values as well. And if V-Ray somehow worked around it, then it would cease to be Lanczos filter, or am I wrong?
Next question is, since Lanczos is pretty sharp filter, is suggested to use it also for animations? I mean, is Lanczos with 2.0 width meant as a good default for just stills, or all around good default?
Thanks.
Avoid using filters with negative components (sharpening filters) like Catmull-Rom or Mitchell-Netravali when using the Progressive sampler as this may increase the render times quite a bit - the sampler needs to take additional image samples to resolve the filter.
Thanks.
