Render elements not saving to EXR
  • Render elements not saving to EXR
    I haven't thoroughly tested it yet, but so far I've found that the VRayMtlID and VRayObjID won't save into EXR channels. They will save to vrimg files, but won't appear after conversion. VRayShadows saves just fine, though.
    Or perhaps the AE EXtractoR just can't see them?
    Anyone else having this problem?
    - Geoff
    Are you saving multi channel EXR or spitting it out to single channel at render time? (I haven't tested VrayMtlID or ObjID yet for this)
    The days when I use to save to VRIMG are gone, but back then I used a bat script to extract the EXR's from the vrimg. I had to manually edit the script to tell it to extract specific elements, because the script was very old and didn't inlcude the newer channels with newer vray versions. Not sure how the AE extractor work, but maybe its a similar issue?
    Kind Regards,
    Morne
      Have you tried saving to exr directly or you get that issue only when converting the .vrimg file to .exr? Also which V-Ray version is this? Moreover could you attach an example exr file?
