Vray 3.3 Info about reached Pass? / Resume Function
  • Vray 3.3 Info about reached Pass? / Resume Function
    Hy All!
    1) Is it possible to look up the reached pass for the progressive image sampler after rendering?
    I know it shows up in the renderinfo but after the rendering process it would be nice to compare.
    2) Is there already the posibilitie to write the info to the image with a framestamp?
    3) Is it possible, in theory, that a progressive vrimg can be loaded into the framebuffer and resume it? In order to reach more passes?
    Thanks!
    Greets Phil
    WS
    DUAL E5-2683 V3 28c/56t @2,6Ghz
    64GB Ram
    ASUS ROG STRIX OC 1080ti
    PALIT SUPER JETSTREAM 780ti
    Node
    I7 2600K @4,40GHZ,
    32GB RAM
    This is the type of thing, along with a lot of other data, that would be nice to have written into the EXR metadata (Scene name/path, Max frame number, render time, render node name, etc.)
      You can either look at the V-Ray log file, or use the %numpasses and %numsubdivs keywords for the VFB stamp.
      See #1
      Yes, it's possible and it's on the "to do" list; I hope we'll get to it soon.
        Recent versions of V-Ray will write the value of all VFB stamp variables into the OpenEXR files. It looks something like this:
        Code:
        vrayInfo/camera (type string): "Camera001"
        vrayInfo/computername (type string): "vlado-thinkpad8"
        vrayInfo/cpu (type string): "INTEL/OctaP3Xeon(MA)"
        vrayInfo/date (type string): "1/11/2016"
        vrayInfo/filename (type string): "test_scene.max"
        vrayInfo/frame (type string): "00000"
        vrayInfo/h (type string): "480"
        vrayInfo/mhz (type string): "0MHz"
        vrayInfo/numPasses (type string): "0"
        vrayInfo/numSubdivs (type string): "0.00"
        vrayInfo/os (type string): "Win8"
        vrayInfo/primitives (type string): "1024"
        vrayInfo/ram (type string): "8080MB"
        vrayInfo/rendertime (type string): " 0h  0m  2.0s"
        vrayInfo/time (type string): "11:17:57 AM"
        vrayInfo/vmem (type string): "134217728MB"
        vrayInfo/vraycore (type string): "3.25.01"
        vrayInfo/vrayrevision (type string): "26567 Jan  4 2016 04:15:01"
        vrayInfo/vrayversion (type string): "Internal V-Ray version Adv 3.35.01"
        vrayInfo/w (type string): "640"
          Ok once more you make me happy very fast!
          I just looked up the 3.3 Docs and under the Systempage there are some "vraystampkeywords" but i didn't see %numpasses and %numsubdivs.
          Is there anywhere the "full" list?
          The resume function would be a very big step further i think...glad to here that you already working on it.
          thanks!
          Greets Phil
          WS
          64GB Ram
          Node
          I7 2600K @4,40GHZ,
          32GB RAM
            Will make sure to add those.
            Click on the '%' button in the stamp toolbar - it will show a pop-up window with all available keywords and their values (see the attachment).
              Thanks vlado all is clear now!
              nice day!
              Greets Phil
              WS
              64GB Ram
              Node
              I7 2600K @4,40GHZ,
              32GB RAM
