Add/remove render nodes on the fly
  • Add/remove render nodes on the fly
    How do we do this?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    In the render dialogue/progress box, expand the Vray Parameters tab and select/deselect which nodes you want.
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
      Awesome. Thanks. In 10 years I have never scrolled down that window!
      Kind Regards,
      Richard Birket
        @Macker
        You mean in the rendering window that shows the progress bar of the render? If so I only have a Common Parameters tab in there. (Vray 3.3)
        Cheers,
        Oliver
        https://www.artstation.com/mokiki
          It wasn't there before 3.x?
          @Macker
          Yes. That's the one. I've found that you have to have started the render with distributed rendering enabled for it to show up (possible bug?).
            Thanks Macker,
            you are 100% correct I didn't have DR turned on. ;P
            Cheers,
            Oliver
