3.3 Glossy reflections
  • 3.3 Glossy reflections
    Good Morning!
    Question about removing the glossy noise as you can see in this example I've made. What would be the process of eradicating in the new 3.3 setup, is it a case of just raising the max sub divs. I dont mind the quality of the rest of the image it is just these glossy areas are a problem.
    https://www.dropbox.com/s/ffdpi56cv6...ossy_.mov?dl=0
    Thanks for any help!
    Adam
    Adam Trowers
    I think in that case you just need higher min/max subdivs in dmc. Since you have fine highlites which flicker too.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Thanks Dmitry
      In the end I checked sub pixel mapping, I know it says don't use it but in this case it has helped a lot, I did test with sub divs and yes raising them a little bit more does begin to eliminate. Don't have the time to use it though, 15200 frame render!
      Adam Trowers
