Editing a Mesh Light ?
  • Editing a Mesh Light ?
    I've created a meshlight from a bit of plane geometry and now want to go back and alter the geometry.
    The options "Editable Poly" under Mesh Light isn't explained in the Docs - I click on Editable Poly and nothing changes / happens.
    Please can someone advise ?
    Many thanks.
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    Okay, if I add an Edit Poly modifier, I can go back in the Modifier Stack and amend my geometry. But still don't understand what the "Editable Poly" button under Mesh Light for a VRayLight does.
    Any ideas ?
    Thanks.
    Jez
      Do you mean the Extract mesh as node option ?
      use this button to restore when you have created a mesh light replacing the actual geometry with the light you can get the original geometry back by clicking on this button.
      Actually there is a box above "Extract mesh as node" that is named this way if your geo is a poly object. Probably this is what you mean. It just specifies which scene object was used for the Light mesh generation.
      Tashko Zashev | chaos.com
