I'm having a problem with the Physical camera, now the vraycamera has been swapped for that one.
No problems so far with the new camera.
Only when I try to setup my camera motion and I check guess vertical tilt (auto vertical tilt correction), it seems to work... on that still frame.
If I playback my animation in preview frame 0 is w/o vertical correction, frame 1 is corrected, and from 2 on alle other frames don't have this auto corrected vertical tilt.
Anyone with a solution for this?
Thank you!
Thank you!
