Different displacement look with 3.30.04 nightly stable
  • Different displacement look with 3.30.04 nightly stable
    I installed 3.30.04 (the stable nightly build) on one of the workstations to test it (because of the reportedly fixed VFB hangs). So far I haven't noticed any hanging but I noticed that the reflections on the displaced water surface in one of our current projects looks different than with 3.30.03. Please see the GIF below. Nothing in the scene or render settings was touched, just installed different Vray versions and I hit render.
    Why does it look different and is it more correct with 3.30.04?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hi Alex,
    The reason for this render difference most probably comes from the changes we made in the displacement node for the latest nightly builds. Actually I can't be sure without testing the scene file.
    You can send us only the displaced mesh (is that Phoenix ocean?) to support@chaosgroup.com
    Tashko Zashev | chaos.com
      Can you elaborate on what you are working regarding the displacement?
      Software:
      Windows 7 Ultimate x64 SP1
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      Intel Core i7-4930K @ 3.40 GHz
      NVIDIA GeForce GTX 780 (4096MB RAM)
      64GB RAM
      DxDiag
        Originally posted by tashko.zashev View Post
        Hi Alex,
        Thanks for the info. No need to send a scene I think. We'll continue with 3.30.03 until the end of the project and install 3.30.04 after that.
        I'm not sure I understand your question. I'm working on a seascape scene if that's what you're asking.
        Aleksandar Mitov
        96GB DDR5
          The difference occurs because of a modification that we did to avoid dark edges when using rounded corners on reflective materials in 3.30.04
            Hmm.. There's no rounded corners on the displaced object. Or you mean the modification affects all reflective objects no matter if rounded corners are used or not? So is the rendered result still correct in terms of realism? No need of any adjustment to the material and object if we move to 3.30.04?
            Aleksandar Mitov
            96GB DDR5
              The modification is in the VRayMtl material, not in the rounded corners as such. See this thread:
              http://forums.chaosgroup.com/showthr...881#post677881
              and also the attached images:
              Old material:
              With modifications:
              As you can see the modified material produces more pleasing results in general.
