Red = slow
  • Red = slow
    Loving the new V-Ray and it is easy to get your head around, however, I have a question. Using the VRaySampleRate to make your image cleaner, is it still supposed to make it faster? I work my scene until there is no more red and it is getting cleaner, but not really faster.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Little bit of red is ok. Means that you used all your image samples.
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
      i think it's the fastest way to render depending on your noise threshold , red on the edges of an object where you have a very bright sky behind it should be normal
      www.kobo9.ch
        The samplerate pass itself doesn't meant anything, it's just presenting you a view of where is using high aa and where is using low aa. You can use it to judge whether vray is trying to clean up areas of your image that should be solved by shading or if it's only working on edges and other areas of contrast.
