UDIM in vrayDisplacementMod
  • UDIM in vrayDisplacementMod
    hi, I've been doing some tests with UDIM and uv tile and I came across this issue.
    When using vrayDisplacementMod in 2D mapping mode, the UDIM or uv tile tag doesn't seem to be working properly, only the first uv set. However, as soon as I change it to 3D mapping or subdivision (this latest one being the fastest), the UDIM token seems to work fine.
    Is this a bug or should we use only Subdivision mode when working with multiple UV sets?
    It's a limitation right now; it's been on the "to do" list for a while and we will get to it.
    V-Ray RT should render it fine, I think.
      good to know, we'll stick to Subdivision then.
      Thanks!
