Auto Display Selected Lights not working?
  • Auto Display Selected Lights not working?
    I'm having an issue with trying to adjust my vray sun. In viewport, I have it set to Realistic, Illuminate with Scene Lights, Auto Display Selected Lights. But for some reason, I'm not seeing any results in the viewport. Not sure why.
    Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    What do you mean by "I'm not seeing any results in the viewport"? Do you see everything in black or the sun light position doesn't get updated? Can you reproduce this on a simple scene? Which V-Ray and 3ds max are you using?
    What if you disable Auto Display Selected Lights option?
      Yes, when I click on a plane light, or the sun, nothing would update. So I restarted max and now it seems to work. BUT, even though the viewport updates, I can not seem to get the sun to render. I even cranked the Multiplier up to 100! I've tried adding another sun as well as even rebooting the machine. Not sure what's going on.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        I've discovered that when I have the plane light for the window the sun is coming through switched on, it was blocking the sun because it was not set to invisible. I had always thought that visibility had more to do with if it's visible to the camera. Anyhow, problem solved.
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
