im doing work for volvo but having problems with the model they sent me, they were from lightwave exported to 3ds...and 60% of the surfaces is missing....anyone here have volvo new models...
Volvo models....please help.
Tags: None
they have quite a few but at usd140 each...and its last years model..
thanks nat..
i did that and even use double sided shaders and render set but still....i think it was exported poorly by a third party software..
anyone know any good object converters from lwo to 3ds?
thanks....ill find someone here with form z...appreciate it very much..
just to add... .3ds file format has a face limit per object of around 32,000 or something close to that, so parts are probably missing because they had too many polygons.
you might want to try importing them as something other than .3ds
.obj is a good one for polygon models. a free import filter for max is available from www.habware.at
thanks guys,,,,it turned out that they exported the model to 3ds using a trial use software that deletes every 5th polygon,,,,thanks again.
