3dsmax 2017
  • Originally posted by Moriah View Post
    Sure, scriptspot isn't loading for me at the moment since the autoback ones are hosted there, but the other one is from Clovis Gay and it's free (this doesn't auto save, just warns you, but does auto incremental save through it) - https://hocuspocus-studio.fr/tools/product/save-button/
    When scriptspot is back up i'll link them, if not i can upload them to dropbox or something.
    Also it isn't very hard to script a customized autoback up, where you can customize your versioning, where it goes to, how many versions to keep, etc. A simplified version would be a timer-based incremental save.
    I just don't get it how autodesk programmers didn't do such thing already... I mean it's so crucial for everyone, specially with such an unstable piece of s... software.
    edit - This is one of them and the one i use at home - http://www.scriptspot.com/3ds-max/scripts/auto-save
    Thanks
    As sod's law would have it, I did do a search on Scriptspot when I saw your message, and as you say, their site is playing up !
    One of the annoying things I find with the version of Autoback up which comes with Max is that it saves based on elapsed time - when I'd rather it saved based on actual usage time. For example, I set my AutobackUp to save every 15mins, but if I stop working for 14mins 50secs (say to take a phone call), then the Autosave will back up in the next 10seconds, even though I've not touched the scene for most of that time.
    So I'd rather it takes inactivity into account.
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    • I'm not sure if that's possible to do in max, and how would you evaluate that inactivity? It's based on mouse movement or some other parameter? Maybe mouse movement would be possible but not sure how taxing it would be on the processing side of things... Maybe someone more experienced than me could figure something out of that sort.
      • Back to 2016 for me too! A lot of crashes too. Though I have been working with Forest Pack for my current project and I don't use it often so it could be related but that's the big problem with max. As soon as you are using some plugins (which you always need) it becomes very difficult to troubleshoot.
        And the biggest problem I have is not even the crashes (I also disabled autosave crap BTW) it is the fact that I just can't install SP3 on my render nodes. I can't even uninstall sp2 and I can't uninstall max 2017. If I try any of those, the installer will freeze all night. I tried on around 10 computers. In fact it worked on only one which didn't have any plugins installed. So one of my plugins might be interfering so I have to try to uninstall the whole thing. So probably not worth it. Max 2018 is around the corner but I have to renew before and I don't feel like renewing at all!
        __________________________________________
        www.strob.net
        Explosion & smoke I did with PhoenixFD
        Little Antman
        See Iron Baby and other of my models on Turbosquid!
        Some RnD involving PhoenixFD
          Not sure how safe that would be, but maybe by tracking the undo stack size. If it doesn't grow for a while, there's no need to autosave.
          -Eugenio
          • Max 2017 is the worst version ever. It's severely broken and the worrying thing is Autodesk seems to have no clue what's wrong with it. Half-way through the version's lifetime, we have three SPs that haven't fixed anything but the most superficial problems. But I guess it was to be expected since the move to rental. Why invest anything in developments once you have your captive audience?
            Check my blog
            • Are you guys serious? I was eager to try out 2017 already now that SP3 is out. Is it really that bad? As in worse than 2016? Now I'm afraid to install it and move production on it as I was hoping to do. I'm hearing all kinds of conflicting opinions.
              Aleksandar Mitov
              www.renarvisuals.com
              office@renarvisuals.com
              AMD Ryzen 9 9950X 16-core
              96GB DDR5
              • Hey BBB3, could you tell in what specific cases are you having crashes, or what is actually broken so far in 2017? Me and my company have been "forced" to rent some 2017 licenses, and i'm afraid sooner or later we'll all have to transition to it.
                Things i found so far that don't work:
                - Certain snapping options are broken
                - UV editor is slower than 2015
                - Physical Cam is a mess
                - 3dsmax settings reset bug is even more common now
                - Backburner adapter gives some weird errors sometimes
                - Weird new UI (that light grey on darker grey doesn't make the overall reading easier)
                Good things:
                - Edit Poly sub element is really fast
                - IPR with Vray nightlies
                - Really fast installation
                - Alembic options were updated + Alembic cache
                • I can not say it is the worst version ever. I have been using it in production since the release, and it is very stable so far. And in my opinion they have done a good job making things faster. The viewport performance has been increased significantly, especially with many objects and manipulations in subobject level on high poly geometry. Try Maya, now that's a nightmare!
                    This is frightening...
                    • I think if you were on WIN7, without 3rd party plugins, it might work perfectly. Walls and Tiles will not work on MAX 2017 and WIN10, but so far, all the other 3rd party plug-ins work fine for me. When I say plug-ins, I mean the big ones. I have many smaller scripts that don't work. You can always install MAX 2017 along-side MAX 2016 and do some testing. I would love to see a report on 3DS MAX adoption rate. I have a feeling it is still rather low.
                      Bobby Parker
                      www.bobby-parker.com
                      e-mail: info@bobby-parker.com
                      phone: 2188206812
                      My current hardware setup:
                      • Ryzen 9 5900x CPU
                      • 128gb Vengeance RGB Pro RAM
                      • NVIDIA GeForce RTX 4090 X2
                      • ​Windows 11 Pro
                      • I still wonder why the fck they HAVE to release a version each fcking year, take some goddamn time to polish your product and let the people restore their faith in it. Look at Rhinoceros 3D. While not the same at least they don't go backwards when they release a new version every few years.
                        A.
                        www.digitaltwins.be
                        • Originally posted by Vizioen View Post
                          I still wonder why the fck they HAVE to release a version each fcking year.
                          Shareholders ?
                          Nicolas Caplat
                          www.intangibles.fr
                            It's good for sales. Sales will go down 2-3 times if they release new version every 2-3 years instead of every year. Imagine the shareholders' reaction when told that sales will go down 2-3 times.
                            In my opinion, the yearly releases should be made free SPs the same way as Chaosgroup does and major versions every 2-3 years at least! I would hardly consider the current year-release cycle a major "version". More like an update or SP. I would be more than happy to pay the current full upgrade price if they did 2-3 times better job at development OR released every 2-3 years instead of each year.
                            Aleksandar Mitov
                            96GB DDR5
                            • Originally posted by NicoC View Post
                              Shareholders ?
                              In my opinion, the yearly releases should be made free SPs the same way as Chaosgroup does and major versions every 2-3 years at least! I would hardly consider the current situation with each new year a release a "version". More like an update or SP.
                              Well if they continue down this path, they don't have to worry about shareholders anymore. Chaosgroup doesn't release a major version each year, each SP is packed with new features or fixes, same as Rhinoceros3D, etc etc If they can do it, why not them?
                              Imo the best software companies are the ones that don't release a new version every year. Lots of people are looking at other packages to do their bidding because of their incompetence. Hopefully they'll wake up just in time and start doing things right. You can not call these SPs, SPs that barely fix what is broken in the first place. I think the whole 3dsmax team consists of 1 intern that only works there mondaymornings after a whole weekend of binge drinking.
                              A.
                              www.digitaltwins.be
                              • Originally posted by Alex_M View Post
                                I dont think that this will still be the chase with rent only licenses. We dont have a choice once all our maintain subscriptions are expired. I think they'll stop this once nobody owns the current max version.
                                If not the half of the max users move away from ad because the price got roughly multiplied by 3-4 which is a crime imo. Than they'll maby move back to oldscool subscription or decrease the price a lot.
                                German guy, sorry for my English.
