Scrim material?
  • Scrim material?
    So this is an odd question, born out of a commercial photography mind-set. Probably something really easy.
    I have an interior scene that contains an out-of-view skylight that is running a bit too bright. The scene is lit with a single HDRI. Of course I can make the hole somewhat smaller, or maybe even a plane to flag of some of the light, but is there a material that lets light pass through it, plus the ability to control how much light passes through? I've heard of the 2-sided translucent material, but I don't know if that's what I'm looking for.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    Maybe a non-renderable plane covering part of the opening.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      just a vray material with a grey opacity map? use vraycolor map and adjust the level with that.
        I don't see where you can adjust the opacity of a colormap unless I'm missing something. Using a plane is the best idea for now, but it can change the dynamics of the opening to block part of it off. Hmmm....
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
          Put the vraycolor in the opacity slot of the material
          Gavin Jeoffreys
          Freelance 3D Generalist
            Originally posted by raven View Post
            put the vraycolor in the opacity slot of the material
            ahh.. Thank you!
            David Anderson
            Software:
            Windows 10 Pro
            Hardware:
            Puget Systems
            TRX40 EATX
            128GB RAM
              What abut just applying a unique glass material to the skylight and adding a bit of gray/black to the fog color? That'll reduce the light coming through.
              Work:
              Dell Precision T7910, Dual Xeon E5-2640 v4 @ 2.40GHz | 32GB RAM | NVIDIA Quadro P2000 5gb | NVIDIA GeForce GTX 980Ti 6GB | NVIDIA GeForce GTX 1080Ti 11GB
              V-Ray Benchmark: CPU 00:52 | GPU 00:32
              Home:
              AMD Threadripper 1950X 3.4GHz 16-Core | 32GB RAM | (2) NVIDIA GeForce GTX 1080Ti 11GB
              V-Ray Benchmark: CPU 00:47 | GPU 00:34
              https://pcpartpicker.com/list/kXKcxG
                Now that's a great idea! With vraycolor in an opacity slot, I couldn't figure that out, even with a gray diffuse. I tried unchecking the diffuse map too. I'll have to play around with that more when I can. I *really* like the glass idea though. Thanks for that.
                David Anderson
                Software:
                Windows 10 Pro
                Hardware:
                Puget Systems
                TRX40 EATX
                128GB RAM
                  there is essentially no difference between using glass ( with a grey colour in the fog colour slot) and a material with a grey colour in the opacity slot. its just a change of slots.
                  plus with the glass material you will need a thickness to the glass to get the fog working , and calculate refractions and fog attenuation.
                  tbh im not sure which would render faster, but the opacity option is easier to set up and requires only a single polygon. in what sense could you not figure it out?
                    I wasn't sure about a value in the difuse channel, or if you have nothing, and only a diffuse color in the VRayColor Map? If you assign a value in VRayColor, what do you use? Black? That would make the most sense I guess, because you would then adjust the opacity of the opacity map?
                    David Anderson
                    Software:
                    Windows 10 Pro
                    Hardware:
                    Puget Systems
                    TRX40 EATX
                    128GB RAM
                      Hey David
                      Keep the diffuse black so it wont bounce any light.
                      Is your Vraycolor set to be full white?
                      You can also leave the opacity value at 100% and just control the transparency buy adjusting your vraycolors values.
                      Gavin Jeoffreys
                        Originally posted by Raven View Post
                        Hey David
                        Vraycolor is set to whatever the default is. It sounds like there's two ways to adjust the opacity then? I would think that leaving VRay color at white and adjusting the opacity would make the most sense... I'll give it a try. Thanks!
                        David Anderson
                        Software:
                        Windows 10 Pro
                        Hardware:
                        Puget Systems
                        TRX40 EATX
                        128GB RAM
                          if you want to use the map percentage spinner to adjust the opcaity, you have to put a black map (or any colour *other* than white) in the slot for it to work. white is 100% opaque, same as no map. so the spinner would be adjusting between opaque and.. opaque.
