An assortment of OSL shaders for your perusal
  • An assortment of OSL shaders for your perusal
    Hi everybody!
    I have some OSL shaders lined up for you which I'll post here one by one as soon as the page for the shader is done.
    To kick this off I present to you...
    The Reflector!
    Links
    Page:
    http://www.rensheeren.com/blog/osl-reflector/
    Download:
    http://www.rensheeren.com/osl/reflector_tex_v002.osl
    http://www.rensheeren.com/osl/rhfunctions.h
    Save both in the same folder, both are needed for the shader to work. Overwrite rhfunctions.h if asked.
    Features
    - Metals and non-metals. Uses complex Fresnel for metals and switches to non-complex for non-metals for quicker rendering.
    - Polarisation for both, should you want to play around with that.
    - Outside medium IOR, for example for objects under water.
    - Aaaand... rough Fresnel!
    ------ EDIT ------
    I've moved this post here!
    Here's a list of all the shaders posted in this thread instead.
    Overview page on my site here.
    Reflector
    Advanced reflections.
    ShowUDIM
    Shows where you are in UV/UDIM space! In text!
    Merge2
    Merge or blend two inputs using several different operations.
    CamMapScale
    A fix for the annoying CamMapPerPixel scaling feature in max.
    MixNormalMaps
    Blend normal maps together… correctly.
    ChannelSwitcher
    Shuffle or mix channels.
    UVTransform
    Transform textures by moving the UV space around.
    ArchGlass
    Simulate multi-paned window glass with only a single-sided plane object.
    Rens Heeren
    Generalist
    WEBSITE - IMDB - LINKEDIN - OSL SHADERS
    That does look nice. I wonder why vray mtl does not have this by default?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Because there are only 24 hours in a day? Because we have also 100 other things to do? Like a denoiser, to take an example at random... Or ftupid Maya 2016.5 stuff... Will get to it, but in the meantime, this is exactly why you have OSL.
      Keep in mind that implementing glossy Fresnel properly is not possible with OSL, it must be done in the BRDF implementation itself. You can only get an approximation with OSL.
        Great work Rens, stuck in Clarisse land at the minute but gonna have a dig through this in July - osl seems really useful. Also just finished some film shots with Jan Volckmann - he's great fun to be around and does really subtle comp work.
          Very cool Rens.
          I'm using your mixNormalMaps map allmost every day. You really deserve your entry
          Looking forward to try this one and see your library grow.
          German guy, sorry for my English.
            Thanks!
            True! It's just a blend between the front facing (0 deg) reflection amount and the Fresnel curve, but it holds up surprisingly well.
            Hey John! How are things? This should work in Clarisse. Oh nice haha, say hi from me. : )
            Rens Heeren
            Generalist
              Originally posted by Ihno View Post
              Very cool Rens.
              Hehe thanks, glad to be in there. : )
              Oh yeah that reminds me, I'll post that one here as well.
              Rens Heeren
              Generalist
                And the second one!
                ShowUDIM
                For displaying the current UDIM tile number, very handy when working with UDIMs!
                Links
                Page:
                http://www.rensheeren.com/blog/osl-show-udim/
                Download links:
                http://www.rensheeren.com/osl/showUDIM_tex_v001.osl
                Save both in the same folder (right click, save as), both are needed for the shader to work. Overwrite rhfunctions.h if asked.
                Features
                - Displays the UDIM tile number as text or as a colour value.
                How to use
                – Create a VRay OSL Texture map.
                – Load in the downloaded .osl shader.
                – Create a VRayLightMtl.
                – Plug the OSL map into the color.
                – Disable 'wrap texture coordinates' in the OSL tex!
                Rens Heeren
                Generalist
                  That's very cool
                    Well we have OSL. So we do have it. You can't implement all the things into the VRayMtl. I mean sure it would make sense but as I see it it is not a high priority issue since we are able to achieve it with OSL to a certain extend.
                    Software:
                    Windows 7 Ultimate x64 SP1
                    3ds Max 2016 SP4
                    V-Ray Adv 3.60.04
                    Hardware:
                    Intel Core i7-4930K @ 3.40 GHz
                    NVIDIA GeForce GTX 780 (4096MB RAM)
                    64GB RAM
                    DxDiag
                      Both very cool Rens!
                      Maxscript made easy....
                      davewortley.wordpress.com
                      Follow me here:
                      facebook.com/MaxMadeEasy
                      If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
                        Hi Rens,
                        Are these VRay OSL Texture maps compatible with Maya?
                        always curious...
                          yes they should be compatible I haven't checked these, but the iridescence.osl worked.
                          Dmitry Vinnik
                          ShowReel:
                            Sweet...thanks Dmitry.
                            always curious...
                            • #15
                              That's very cool
                              Thanks! With this it shouldn't be hard to make some 8-bit adventure game in activeshade mode. No need for a boss key hehehe : )
                              Thanks! I have a couple more ready to go in the next few days!
                              I haven't tested it yet, but if thin film works in Maya as Dmitry said then this should hopefully work as well. Texture/colour inputs are different in Max and other applications. The reflector shader just checks to see if VRay is used and then switches the input type, so if it works in Maya with VRay it should work everywhere. : )
                              Rens Heeren
                              Generalist
