Red Shadows
  • Red Shadows
    I'm having an issue with a material in that I'm getting red shadow areas. I've rendered the scene with two other darker materials with no issues, so I can't imaging it's anything with lighting. In fact, if you look at the gap between the two file drawers, you'll see it there. The material itself is nothing fancy - just a bitmat in the diffuse slot. I'm using the default BF/LC setup with 3.40.02
    Any ideas as to what's going on?
Name:	Screen Shot 2016-06-30 at 8.12.53 AM.png
ID:	884852Click image for larger version
Name:	Screen Shot 2016-06-30 at 8.12.24 AM.jpg
ID:	884853Click image for larger version
Name:	Screen Shot 2016-06-30 at 8.18.39 AM.jpg
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    That looks like there's a non-vray material in the scene?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
      Is there an easy way to find that? Or is it better/easier just to fire up V-Ray scene converter?
      Edit: I just ran scene converter, but no difference to output.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Isn't that just how Lightcache works? It usually produces quite saturated shadows. As a test you could use BF instead of LC for the secondary GI, see if that fixes it.
          BF/BF didn't do anything either except slow the render WAY down... What DID seem to help however, was to turn GI Saturation from 1.0 to .5 This made a big difference, but I'm not sure if that's the "right way" to fix it? Even though the color is less noticeable, the shadows are still "reversed" in that they are actually lighter in some spots.
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
            I wonder if you try using override material and put a white material as GI override and see if that handles it. It may just work, at which point you have at least worked out what the problem is and maybe a solution can be arranged from there.
              looks like your lighter material is just way to bright. resulting in producing too much gi. what are the rgb values on this bitmap?
              Marcin Piotrowski
              youtube
              CGI OCIO config 04
                They are 235, 193, 144. I'll have to try colorcorrect and maybe darken a bit, and then bring the levels back up in post. I'd rather keep it fairly simple whatever the fix may be.
                David Anderson
                Software:
                Windows 10 Pro
                Hardware:
                Puget Systems
                TRX40 EATX
                128GB RAM
                  too high imho. I consider 160 good value for simple white interior wall. and that wood is darker than white wall. and it is fairly simple: correct input gives you correct result.
                  what does your color mapping look like?
                  Marcin Piotrowski
                  youtube
                  CGI OCIO config 04
                    by 160 I mean color directly in color swatch of VRayMat diffuse. it will be higher if that would be texture used in diffuse slot - gamma corection.
                    If you don't like to be bothered by math prepare 3 simple gray VRay materials in editor slot: rgb 56 (half gray), 160 (white interior wall) and 185 (common white paper) and use those as reference for brightness of your shaders. Than use rgb multiplier and/or curve in output section of max's bitmap leader.
                    Marcin Piotrowski
                    youtube
                    CGI OCIO config 04
                      Any chance the xform is way off? Maybe reset it?
                        I think you've hit on the issue. I put a Color Correction on the material and turned the brightness and saturation down by 25%, Contrast down 10%. WAY better. I don't seem to have any of those issues. Since I'm outputting to 16-bit, I was easily able to then "pull" the material levels back up to the RGB values of the swatch without issue. Thanks.
                        David Anderson
                        Software:
                        Windows 10 Pro
                        Hardware:
                        Puget Systems
                        TRX40 EATX
                        128GB RAM
                          now with darker diffuse colours you can boost the lights to get previous exposure.
                          I'm glad I could help.
                          Marcin Piotrowski
                          youtube
                          CGI OCIO config 04
