applying UVs to multiple objects
  • applying UVs to multiple objects
    Is it possible to apply a texture that needs to align from object to object, without needing to apply it once on all selected objects?
    For example I have a brick material that I want to be seamless across multiple floors. If I apply it correctly to one floor and then copy and paste onto the next, the texture will be misaligned. The only way I've know is the select all the objects and apply the UV once. But then it becomes a hassle when things are changing around and new geometry is added.
    Any tricks I've missed?
    Brendan Coyle | www.brendancoyle.com
    using the use pivot points option at the begining of the modifier stack will help with this maybe
    Architectural and Product Visualization at MITVIZ
    http://www.mitviz.com/
    http://mitviz.blogspot.com/
    http://www.flickr.com/photos/shawnmitford/
    i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
      that's what the acquire button is for.
      you can go absolute (you want this one) or relative.
        Unless I'm misunderstanding the OP, he'd want to select his objects, and make sure that use pivots option is *off* before applying the UVW modifier. So that it applies a single modifier instanced over all the objects at once
