Rendered image gone
  • Rendered image gone
    Hi all
    I have just finished a render that took 3days using direct computation at 5000*3750 and i cant retrieve it. I was using the Vray frame buffer and when you minimize it or move it while rendering will remove rendered buckets. Now when i click show last rendered in vray it comes up blank, when i go duplicate to max buffer nothing happens. Help please....
    I dont want to restart max for fear that the image which should still be in memory is erased.
    Max6, Vray1.45.70
    Regards
    GALACTUS
    was there a reason for using direct comp?
      It was one of those "lets us have it when its done" projects, so i thought hey what the hell, one machine was just sitting there processing some useless microsoft cycles so.... first bounce QMC second bounce light maps. I thought using the Vray VFB would also eliminate the "error creating bitmap" message.
      Also if you keep increasing the light map subdivs you get to a point where it starts to return black samples in increasing numbers ( maybe the energy has completely dissipated heh heh)
      GALACTUS
        hey weren't you the one elf that liked to say how much they liked to use direct comp?
          Guilty
          I look forward to the publication of my new book.....
          "Quasi-Monte Carlo The Way of the Enlightened Pixel Warrior"
          1st 5 buyers get a brand new pentiumXI with 5THZ ram to render QMC calcs in almost real time.
          Thanks you guys i have managed to forget my problems, am going down the irradiance route while i break down the scene and try to isolate why it did what it did
          GALACTUS
