Rendering multiple cameras
  • Rendering multiple cameras
    Hi
    How do I render multiple cameras one after the other which are not part of an animation ?
    Thanks
    N
    www.morphic.tv
    www.niallcochrane.co.uk
    Hiya
    I've in the past successfully used Camera Manager script from Michael Comet. You can get it from
    http://www.comet-cartoons.com/toons/maxscript.cfm
    Dave
    ________________
    [ www.thumpa.net ]
      You can also try WkSequenceManager V1.0
      Get it from here:
      http://perso.wanadoo.fr/werwack/maxs...anagerV1.0.htm
      ________________
      [ www.thumpa.net ]
        You can also do it just using the post effects.
          Yes indeed you can do it with Video Post too, but the script solutions allow you to see your camera edits in the viewports. At the end of the day it depends on how interactive you need it to be.
          ________________
          [ www.thumpa.net ]
            For the most part I just set it up in Backburner.
            -dave
            Cheers,
            -dave
            ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
              Another option is RPManager (http://www.rpmanager.com)
              Great plugin for Render Pass management.
              sigpic
              Vu Nguyen
              www.loftanimation.com.au
                Quasi Anim
                You can use a animation with for example 10 Frames. All the frames are rendered in a Imagesequence,
                thus individual pictures are rendert.
                I make it in this way:
                Create a camera, hit the animbutton, in frame 0 you have your first shot.
                Move to frame 10, move your camera to the next view, etcetera etcetera
                (if you have already cameras for the shots you can use "Ctrl + c" to align your view)
                Then in the Renderdialog, write your Viewnumbers in the "Frames" field,
                Select your place to store the Images, hit render.
                Sorry for my bad english
                Oli
                  Thankyou all for all your replies.
                  I ended up using Video Post which, is actually quite straight forward.
                  Regards
                  N
                  www.morphic.tv
